Shoutbox » MsgHelp Archive » Skype & Technology » Tech Talk » Wireless router connection
TylerG
O.P. Huh?  Wireless router connection
My computer connects with a wireless router with a PCI card.  But every once and a while it will lose connection, and all my downloads and stuff are cancelled.  Is there anyway to prevent losing connection?
[Image: lardotest4on.png]
05-25-2005 07:24 PM
saralk
RE: Wireless router connection
what is the signal strength between your PC and your router.
If it is quite low, then you need to move your router and PC closer together. Or, if your pc is under your desk, get an ariel extension cable.
London · New York · Paris
Est. 1989
05-25-2005 07:37 PM
TylerG
O.P. RE: Wireless router connection
My computer connection speed is usually low, but I was moving it around and lately it has been Very High:)  My computer is in my room upstairs, and my router is downstairs.
05-25-2005 07:41 PM
.blade//
It's likely because of interference of some sort it loses the signal. This wouldn't happen if they were close (and you can check signal strength in the control panel).
05-25-2005 08:02 PM
Anubis
I had that problem a while ago.
What I did was go into the router settings and change the channel it was using to another channel. The problems never happened again since that.
I was using channel 11, but changed to 3.
May not work for you, but try changing channels, often solves glitches like this.
[Image: anubis5hq.png]
05-25-2005 08:05 PM
TylerG
Thanks for the feedback:)  I will try these suggestions
05-25-2005 08:07 PM
Striker
43 / Male / –
you have a cordless phone?,, that sometimes can screw things up
also.. how far away are you from the router?..
and you can play with the antennas to see if that helps
05-25-2005 10:08 PM
TylerG
I messed with the antenna and it has been working great since.  I just hope it keeps it up.
05-26-2005 01:32 AM
SikStyles
DeathCult
but why wont u move it closer to the computer? cant be done?
hmm yea mite wanna change channels or maybe move the router away from sometin that mite disturbe it..phone..maybe tv..radio.,i dunno much bout routers..
You're still breathing? Why?
[Image: userbar.jpg]
05-26-2005 03:11 AM
Concord Dawn
This is a loopy fruit.
Cordless phones only interfere with Wireless networks when they use the 2.5(4 possibly? I'm not 100% sure)Ghz frequency. I have 5Ghz and 900MHz phones in my house and they work fine and do not interfere with my wireless connection.
[Image: 7.png]
05-26-2005 03:24 AM
